TRY IT ON LOW FAN SPEED AND SEE IF IT LEAKS , MAKE SURE IF THERE IS A HOSE OR SMALL DRAIN PAN UNDER COIL THAT IT IS CLEAN AND FREE OF DIRT .SOMETIMES ON HIGH WATER IS BLOWN PAST DRAIN PAN AND DRIPS ON FLOOR , THIS MAY BE A BAD DESIGN. IF THERE IS A FILTER CLEAN IT
The defrost drain hole in the freezer side is frozen closed. Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
You will have to stick a coat hanger up inside drain to unclog it. Also you should check hole on rubber nozzle of drain and cut it bigger if needed. Pan should have water in it.
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
