SOURCE: Lumix Simple Viewer - Copying files to CD
I have "acquired" photographs from my Panasonic Lumix DMC-FX 8 using Lumix Simple Viewer onto my computer, and I am able to view them. However, I need them in a format that I can now copy them onto a CD or attach them as files to emails (without using the "Send by e-mail" function). I am sure this is simple, but is anyone able to help me?
SOURCE: Video playback problem on lumix dmc tz3
I don't have a solution to the first part of your dilemma (why it won't playback) but I do have a solution for deleting the file. On your camera are "hidden" file folders. When you connect your camera to your computer, you probably only see two folders (that's all I see for my DMC-LZ8). But there are more, and your undeletable picture/video is in one of these folders. Find the folder and you'll find the file. Delete it from your camera using the computer to do the command. Problem solved. Okay, so how do you find the hidden folders? I have a Mac, so my process was this: 1) Connect camera to computer; 2) Select/open camera icon (looks like "volume disk"); 3) From top Finder bar, select File then Find; 4) Select the camera volume to limit your search to the camera (not HD or other external hard drives you may have connected to your computer); 5) Select "Kind" and in the next dropdown button "Folders". Voila. Happy searching. My hidden "undeletable" video files were in a folder called "100_PANA". I selected them then moved them to the Trash. Be sure to eject your camera properly (don't just turn it off or disconnect it).
Good luck. I hope this helps.
PS - My theory is that this occurred after an upload to my computer got unexpectedly disconnected before everything finished loading or else the camera got disconnected from the computer incorrectly even if the upload had already finished (see above comment to eject camera properly). In either case, the blank/black screen, unviewable but "there" on the camera taking up memory photos/videos problem happened to me, too. The above actions resolved it for me.
SOURCE: how do you delete multiple pictures from the
The quickest way to multiple delete pictures from you camera after you have copied or backed them up is to use the camera's menu to format the camera or/and card.
Regards.
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
SOURCE: Lumix dmc-ts1 will not turn on after taking underwater pictures
I had the same problem, half way through snorkelling the screen just went black and the camera wouldnt turn back on, HELP PLEASE!!!
