see this causes, and use the common sense.God bless you f the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
please see the causes and use the common sense. God bless you f the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Well-made aluminum canoes are rugged and most dents can be punched out. They are the ultimate no-maintenance canoe. Even when left outdoors all year, neither rain nor snow affects them and they will not take on weight with age. They are rigged with flotation air tanks or foam compartments to render them unsinkable. On the downside, aluminum canoes are noisy, tend to cling to (rather than glide over) rocks, and conduct heat and cold. Most aluminum canoes carry their beam well forward and aft so that they push rather than cut through the water. This hull design, however, makes them initially more stable and increases their carrying capacity.
24X Paper Jam message displays, Paper jammed over the Pass Thru Sensor. (The printer displays the value of X for the paper tray where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
