Hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
