Canon PowerShot S3 IS Digital Camera Logo
Posted on Apr 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hard Time Turning On
In a Canon Powershot S3 IS cam, you have to turn the switch to the right so it will turn on. When I am trying to turn on my CANON POWERSHOT S3 IS, it takes a long time(trying to turn it on all over again) and I think the turn-on switch is stuck. I think its stuck because whenever i try to turn on my cam, the switch won't fully open. But when I want to view my pics, the switch works perfectly fine! I don't know what happened! Pls solve my problem ASAP!!
-jon tantan
Anonymous
Level 2:
  • Expert 98 Answers
  • Posted on Apr 24, 2009
Anonymous
Expert
Level 2:
Answers
98
Questions
0
Helped
22508
Points
224
For viewing you must turn to the right, it means your switch for record on is defective.
Your Canon repaircenter can fix this for you, if not contact Rotronica in the Netherlands for repair.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
391
Points
Does it turn on to view the photos by turning to the left? if so, hitting the shutter button once should move it to the photo taking mode.
1helpful
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Camera beeps but won't turn on
You are sure the battery is still ok?
Please don't try to switch on the camera as long as it is connected to a power supply or a computer with the USB cable, because it won't switch on that way. Only with a correctly charged battery.
Read other post of me to find out what to do with your battery, or just ask if you can't go on.
1helpful
Problems with macro close ups
First make sure the lens is clean. Now set the dial to P mode. Hold down the flower button for a few seconds and the camera will go into "super macro" mode - keep watching the screen or the viewfinder until this happens. You might also feel the zoom resetting itself. You can now go right up to the subject, literally almost touching it - be careful not to damage the lens by hitting the subject! I think in normal macro mode 4" is too close.
Canon PowerShot S3 Is
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
2answers
Canon Powershot s3 will not turn on or review photos.
It is likely that an internal integrated circuit in the DC/DC board is damaged.
You will need to have your camera reviewed by a qualified technician to have it repaired, since it requires open the camera and evaluate the DC/DC board performance.
Best regards,
Powershot s3 is
clean off all fo your contacts on the inside and the battery door, even try puling up on the connectors so that they get a good connection
Can i connect this camera to my computer and use it as a web cam
No, digital cameras usually cannot be used as webcams unfortunately because they do not have the correct softwear to hook up to a computer.
Sorry!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
