SOURCE: "High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Testimonial: "Thank you for your reassuring response. I'll know whether I have a continuing problem at 3 am tomorrow."
stopped up drain,tear in gasket,not going into defrost soon enough
