There are a few potential reasons why the touchscreen on your Konka TV Android device might not be working properly. Here are a few things you can try to troubleshoot the issue:
Restart the device: Sometimes, a simple restart can fix issues with the touchscreen. To do this, turn off the device and then turn it back on again.
Check for updates: Make sure that you have the latest software updates installed on your device. Updating the software can sometimes fix issues with the touchscreen.
Clean the screen: Dust and dirt can build up on the touchscreen and interfere with its operation. Try cleaning the screen with a soft, dry cloth to remove any debris.
Check for hardware issues: If the touchscreen still isn't working after trying the above steps, there may be a hardware issue. In this case, you may need to have the device inspected by a technician or bring it to a service center for repair.
If you are still experiencing issues with the touchscreen on your Konka TV Android device after trying these steps, you may want to contact the manufacturer or a qualified technician for further assistance.
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable (If the Touchscreen is not broken of coerce (: ) .
If this solution not helped you then you must to change your Touchscreen.
It could be that your touchscreen (digitizer) is PARTLY broken.
To confirm, try rotating your tablet 180 degrees, and then touch the home button again.
If it works when rotated then you need a new touchscreen.
I hope you are good with precision tools, and have good mechanical skills and instincts: it's a rather intricate job to locate the locking tabs and screws that attach the touchscreen to the insides of the tablet, then remove them, and finally to replace a touchscreen. And then reattach all necessary fasteners, and test whether it will work properly.
EASIER FIX: go to Ebay and buy a used Trio tablet. it may cost you only $40 to $50 maybe even less!
Before you open up your computer, try downloading the touchscreen drivers from Fujitsu's website and re-installing them. Sometimes they just get flaky.
