I just got a nokia N95 a few days ago and have experienced problems when I tried to change the PIN code on it as I was advised to do. Phone kept on rejecting the 'verify pin code' although I tried several times. Eventually it loked up (off course arghhhhh) and requested the PUK code and unlocked. Every time I tried to change the code it kept rejecting the 2nd attempt at verifying the code and would request the PUK code again. I tried switching the phone off and on again... but same thing happened. Can no longer use the phone as it keeps on asking me a new pin code and verifying that same pin code. It accepts the first new pin code but rejects the verifying one.... Vicious circle. In the end I decided to pull the battery and my sim card out of it and switching phone back on... all went well so I inserted my sim card back into the device. Now it says SIM card rejected and there's nothing I can do.
SOURCE: pin code blocked and then sim card rejected
Hi
You can obtain the puk code by contacting your phone service provider.
If you have entered the puk code wrong too many times (tried to guess it) the sim card has disabled itself, and its useless, you will have to contact your phone service provider to obtain another sim card.
I've explained more about it here
SOURCE: on my nokia 6300 i put in the wrong pin, even thou...
sim card rejected that means sim card is not anymore. and then i can suggest you is only you buy new sim card. but your phone is safe and secure. nest time whenever you got problem of puk code then contact to your sim card service center and if your phone got locked then try my tipshttp://www.fixya.com/support/r4893613-unlock_code_nokia_phone
Thanks
SOURCE: Nokia N 70 - Error - 'Sim Card Rejected'
IF you put PUK code many times depending on the model it wil lock the sim card. This is because to prevent unathorised person using your SIM card.
Default PIN code for nokia mobile is 0000
PUK code will be given by the service provider only.
Please call your service provider or go to service provider office,they will assist you in this issue.And they will have a security check like name,Phone number and other information to check weather the SIM card belongs to you only.Then they will assit you.
Thanx
SOURCE: firstly i insert correct puk
It reject the Sim means it locked to Network,You need to unlock it,get the Unlock code at here
http://www.mobile-unlocker.com/ and Unlock it.
