This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Change the toner cartridge , i have many units phaser3200 and this is one of
the problem , but only if the toner cartridge is very old and many time
refilled , if not , change the Laser unit .
Remove a misfed document if the copier displays a message
reading "Document Jam." Lift up the document feeder cover and turn the
roller to remove an Exit Misfed document. Lower the document feeder back
into place and feed the document through again. If the document is
jammed on the Input side, open the cover and gently pull the misfed
document to the right and out of the feeder.
Pull out the paper tray and lift the tray to release it from
the copier if the copier displays a message reading "Paper Jam O."
Remove the jammed document, and open and close the side panel of the
copier to clear the error message.
Unplug the power cord and plug it back in again if the copier
displays a message reading "Fuser Error, Open Heat Error, Heating Error
and Overheat." If the problem persists, call for a service.
Remove the toner cartridge and shake it from side to side if
the copier displays a message reading "No Developer Cartridge." If this
does not do the trick, you may need to replace the cartridge. Pull the
release latch to open the side cover, and open the front cover. Twist
the cartridge locking-lever upwards and remove the toner cartridge.
Insert the new cartridge and lock the lever into place. Shut the front
cover and the side cover.
Power off the unit and power it on again if the copier
displays a message reading "LSU Error." A problem has occurred with the
Laser Scanning Unit. If the problem persists, call for a service.
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer
then back on again. If the problem persists, see the manual." Is
displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy
large documents such as books, make sure that you secure the clear space
in front of the tray before printing / copying. When the error message
above is displayed and if you find something is in front of the tray,
remove it. Then, turn OFF the printer and back ON again and the printer
will be ready for printing.
If you still have the trouble, contact the repair service. Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Try reaching around the back, you'll notice a rounded tab pointing back from another door on the print unit--you can pop this cover up and close it. That reset the error for me.
