Question about Nikon D3200 24.2 MP CMOS Digital SLR with 18-55mm f/3.5-5.6 AF-S DX VR NIKKOR Zoom Lens
DSLR says lens not attached
Hi, I have an odd problem. My Nikon D3200 worked fine with my M42 adapter and lenses for two months. But a week ago, when I tried to use my 35mm lens, it said "Lens not attached". I've tried everything, but no lenses were accepted except my kit 18-55. Then suddenly, after maybe an hour, I've tried the m42 lens again, and it was okay. Until today. I use my DSLR every day, and it works fine, except this problem, which seems to occur randomly. Do you know any solutions to this problem? I need it to school, especially today when I have practice in a studio. Thanks
    Sergeant:
  • 201 Answers
Hey there,
It sounds like your problem is related to the aperture setting on your lens. The aperture ring should be set to the smallest aperture usually f22 when attaching these older lens. Most lens aperture rings will provide a locking mechanism for that ring on the lens.
The aperture would be then set through the camera, not on the lens. Also some nikons have a lens preset on their menu, where you can inform the camera which lens is attached. Most of the older lens lack any terminal points for communicating with the camera automatically, therefore you will have to fill in the data manually to get better functionality out of the lens camera combo.
Posted on Oct 03, 2013
6ya staff
SOURCE:
eightfps
  • 63 Answers
SOURCE: Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Posted on Apr 16, 2010
Brian Williams
  • 48 Answers
SOURCE: FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Posted on Mar 02, 2009
Glyn Kendall
  • 146 Answers
SOURCE: Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Posted on Jul 03, 2009
Glyn Kendall
  • 146 Answers
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Posted on Jul 04, 2009
Anonymous
  • 149 Answers
SOURCE: NIKON D80; Nikon 18- 135 G LENS, Camera doesn not recognise lens
try to clean the contact of the lens & camera
Posted on Oct 16, 2009
How can I determine which Sigma and Tamron lenses will work with my Nikon D3200? (I know they have to fit my Nikon F mount.)
There are three things you have to consider when getting lenses for the D3200.
First, you already know that the lens has to have the Nikon F mount.
Second, in order to autofocus, the lens must have a focus motor since the D3200 doesn't have one itself. Sigma designates lenses with the focus motor as HSM. Tamron designates theirs as USD. Lenses that don't have the focus motor will still work with the D3200, you just have to focus manually.
Third, the lens must have the electronics to communicate with the camera in order for the exposure meter to work. Any Sigma or Tamron lenses designed for digital cameras will have the electronics. Older mechanical lenses, including those from Nikon, will still work with the D3200, but you must set the exposure manually, without any help from the camera's light meter.
May 10, 2014 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Can I use Vivitar Mc 50mm F1.7 Lens on Nikon D3200 ?
Vivitar makes lenses with a variety of lens mounts to fit different brands of cameras. If the lens has a Nikon mount then it will work on the D3200. If it has some other mount then it will not work.
Feb 27, 2014 | Vivitar Pentax Mc 50mm F1.7 Lens Pk...
Does vivitar 100-300 lens mount on nikon d3200
Vivitar makes lenses with a variety of lens mounts. If the lens has a Nikon mount then it will mount onto a D3200. If has another mount, then it will not.
Feb 12, 2014 | Vivitar Cameras
How to mount a tair 300 on a nikon DSLR camera???
Sorry, you can't. The Tair 300mm uses the M42 mount, while Nikon SLRs (film and digital) use the Nikon F mount. Due to the deeper flange distance of the Nikon mount, M42 lenses cannot be adapted to Nikon cameras without losing infinity focus.
Nov 27, 2012 | Cameras
What's your pwill Tamron AF 1780 Lens 80mm - 210 work on a sony 200A dslrmmroblem?
you need a proper t2 adapter. when you remove the m42 adaptor on tair lens, you can attach the proper t2 to nikon adaptor on it. check my tair 300 photo. it has "t2 to m42" adapter on it. please be sure that find the correct adapter. i bought several adapters to find the correct one. one of them was different than t2 adapter but looking alike and sold as t2 by seller. it is hard to find the correct adapter. i guess there are variants of that standard(which is odd).
Feb 01, 2012 | Tamron 80-210mm f/4.5-5.6 Lens
I have a Soligor C/D 28 - 200 mm, f3.5 - 5.3 Macro lens used quiet well on a Minolta XG1 and want to know whether I can use it on a Nikon D90 DSLR and if so, where can I source an adapter. Is it worth the...
The lense will probably work with an adapter. try ebay. i purchased one for my canon lenses for macro work. note that the focal length of the nikon is 46.5 and the minolta is 43.5 and infinity will not work with out an adapter with a correcting lense. you will find a adapter with out a lense will work fine for macro.
Jul 19, 2010 | Cameras
Pentax ES2; do bayonet lens fit digital Pentax SLR?
Any Pentax K-mount lens will fit any Pentax DSLR. The DSLR will fire the shutter.  There is a menu setting (RTFM) which allows the use of older lenses, but you will lose some of the automation (again RTFM). Remember to allow that the effective focal length when using a "film" lens on a DSLR body goes up by 50%.
A standard 50mm lens becomes a 75mm equivalent, but stays a large aperture.
Nov 25, 2009 | Pentax ME Super 35mm SLR Camera
Mount for rollei pqs lense to nikon dslr body
The rollei 600x mount lenses communicate to the camera via the gold plated contacts. In addition, the 350mm PQS is a medium format lens. There is currently no such adapter.
Apr 06, 2009 | Rollei 350mm f/5.6 Zeiss PQS Lens
Sigma 600mm lens mount
You may be able to find a Konica toMinolta or Konica to M42 adaptor. Some adaptors are available...some aren't; it depends upon the film plane dist. and mount diameter. For instance you can get a Nikon to Canon adaptor, you can't get a Canon to Nikon adaptor. Email KonicaMinolta and ask them.
Jan 18, 2008 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Nikon D3200 24.2 MP CMOS Digital SLR with 18-55mm f/3.5-5.6 AF-S DX VR NIKKOR Zoom Lens Logo
919 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
