Dodge Ram 1500 Ac Compressor Clutch Assembly 2002 2003 With 4 7 Liter Logo
Mike Fleming Posted on Sep 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I jump the compressor clutch on my 2002 dodge ram 1500 ?
John Edwards
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Dec 12, 2016
John Edwards
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
Helped
4811
Points
21
Just unplug the cluch wiring harness plug thats it ....thats the electrical switch wires.....just unplug the AC clutch plug-in wires and it disables the clutch. Simple as that.
Timothy Merchant
Level 2:
New Friend:
  • Expert 175 Answers
  • Posted on Sep 26, 2013
Timothy Merchant
Expert
Level 2:
New Friend:
Answers
175
Questions
0
Helped
60306
Points
445
Hi pressor switch.but be cairfol
2006 Dodge Ram 1500 5.7 4x4. What fuse runs the 4x4 please?
It isn't specified. There is more than one fuse that covers transmission. You would need an auto electrician or a transmission expert to connect a pro grade scan tool computer and diagnose if the switch or solenoid is faulty. A scan tool at this level is bi-directional and can command solenoids to operate and confirm that they do.
https://www.google.com/search?q=auto+electrician+near+me
Fuse Box Diagram Dodge Ram 1500/2500 (2002-2009)
https://fuse-box.info > dodge > dodge-ram-1500-2500-...
Fuse box diagram (location and assignment of electrical fuses) for Dodge Ram / Ram Pickup 1500/2500 (2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009).
2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram
https://knigaproavto.ru > ... > Dodge > Ram (Pickup)
Nov 16, 2018 - 2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram ; 5, 20, except Base: Sunroof ; 6, 40, Diesel ('06): Wastegate Solenoid, Drive Fan Radiator ; 6 ...
2006 5.7 ram 1500 fuse box diagram - DodgeForum.com
https://dodgeforum.com > ... > 3rd Gen Ram Tech
3rd Gen Ram Tech - 2006 5.7 ram 1500 fuse box diagram - I was hoping somebody had a fusebox diagram kicking around. The inside of my fuse box cover does not ...
Fuses and relay Dodge Ram 2002-2008
https://fusesdiagram.com > Dodge
Mar 27, 2017 - For Dodge Ram 1500, Dodge Ram 2500, Dodge Ram 3500 - 2002, 2003, 2004, 2005, 2006, 2007, 2008 model year. Cigarette lighter fuse - Fuse box in ..
Dodge Ram 1500 AC Compressor Clutch Bearing
Yes-- the Clutch Hub Bearing Assy
You can see that on any internet
parts site
Don't see your concern
Dodge A/C makes clicking sound under hood
If the noise is the ac clutch bearing you can replace the ac clutch without replacing the compressor on most models.
1helpful
A/c clutch does not kick on my 02 ram could ths because low on or no freeon
Could be, at low pressure cycling switch jump wire, switch screw into accumulor if compressor come on recharge a/c system, if not check fuse and relays and compressor coil.
2answers
2002 Dodge Ram 1500 A/C Blows Hot When Stopped and Clicking Sound
if the compressor is turning on and and off R1-34 level is low recharge system.
4helpful
A/C 2001 Dodge Dakota compressor wont come on
Check the high side ac clutch cut out switch,witch could be in back of compressor,or in a high side line.By pass the switch to see if the compressor will come on.Also the ac module could be gone out.First check the ac clutch relay,or better yet swap it out with a relay just like it,same number will be on the relay,this will tell you if it is the relay.
2answers
I can't get power to the clutch on my air conditioner/dodge 2001
Need way more info. Like which clutch? A/C or tranny? Which engine?
Dodge Ram AC not blowing cold
By pass both pressure switches one at a time with small wire or a paper clip. If comperssor kicks on replace the swich that you bypassed.
if not it could be the fan clutch ot the compressor. Compressor runs about $400.00
1helpful
1500 Conversion Van AC stays on, van overheats. Pulled the AC clutch fan relay and it fixed the overheating thus far, but really need the AC this time of the year. Please help.
ONE SUGGESTION COULD BE TO SWAP THE RELAY FOR ANOTHER TO SEE IF THIS FIXES THE PROBLEM. IF IT DOESN'T, THEN PERHAPS THE COMPRESSOR CLUTCH IS STUCK IN THE CLOSED POSITION. UNPLUG THE CLUTCH TO SEE IF THE COMPRESSOR STOPS. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. GOOD LUCK
Top Automotive AC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Automotive AC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
