SOURCE: dewalt dc 980,when i spin the torque dial from 1
You need to get a new transmission. There is a spring and pin that get worn in the transmission. Dewalt doesn't sell just the spring and pin. You will have to get the whole transmission. The part number for the transmission is 397892-05 for the dc980. To change it you undo the screws holding the housing together. (Make sure battery is removed first.) Undo 4 screws holding front assy on and remove. Undo back cap screws and remove. Pull the right side cover off and leave drill seated on bench. Do not pull entire assy out of left handle. slightly angle the motor transmission assy and slide transmission off. Replace with new transmission. (Lining up teeth is not easy but keep at it until you get it.) Replace motor and transmission assy and reassemble in the reverse order above.
SOURCE: Dewalt D21810KS-XE is described as having a
Yes, that would be to adjust the screw driving torque etc.
Testimonial: "Greta! Yes you understood the idfea. Thank you very much."
