JBL PSW-D110 Speaker Logo
A
Anonymous Posted on Sep 26, 2013
000000000000060301 POWER AMP MODULO S53AMI - JBL PSW-D110 Speaker
How to calculate 5^(-1)mod 792
I am sorry, but I was under the impression that the modulo operation involves integer divisions only. This means it involves only integers. However 5^(-1) is a rational number that is not an integer. And then I could be wrong.
As to doing modulo operations with this calculator, well you can't. Sorry again.
1helpful
Mi alarma esta muy sensible, con cualquier ruido, como le hago para bajarle de intensidad?
Hola, debes buscar el sensor de impacto, normalmente lo instalan en el area inferior del volante o timon, es modulo que usualmente esta conectado al modulo de alarma por tres cables, tiene un indicador LED y un control de sensibilidad que se ajusta con un desarmador plano pequenio.
3helpful
How to do modulo operation in casio fx991ms
The fx-115ES does not have a modulo operator. However, it is possible to compute the remainder using integer arithmetic. Press MODE 4 to shift into integer mode. Then calculate A modulo B as
A - B * (A / B). For example, to calculate 41 modulo 6, press
4 1 - 6 * ( 4 1 / 6 ) =
and get 5.
Press MODE 1 to return to real arithmetic.
3helpful
How can i calculate modulo division on the calculator
and get 5.
1helpful
Please tell me how to find out the mod like 2%100
A - B * (A / B). For example, to calculate 2 modulo 100, press
2 - 1 0 0 * ( 2/ 1 0 0 ) =
and get 2.
How to calculate the module of a number using a scinentific calculater
and get 5.
2answers
HOW TO REPAIR A DAMAGED JBL PB12 it just stopped working, somebody told me it was unfixable due the part are very hard to get I guess the internal amplifier got broken
There is a quick way to find out if the parts are hard to get. Look inside a make a note of the IC and Transistor numbers. Don't bother with the resistors and caps. Put the numbers into Google and see what comes up.
ARS108 gone
Since Acoustic Research went out of business, I too have been looking for a solution similar to yours. I may have found an alternative to throwing away this really nice speaker. I found a company on the web that appears to sell an amp that may fit nicely into this speaker enclosure for $99.00. Check it out...
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=300-805
Tenderfoot56
(I'm not in any way associated with this company, just a suggestion)
Conguent modulo
I did a google search using the words "congruent modulo Computer speakers" perhaps you might want to do this too.
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
