Washing Machines Logo
Posted on Sep 26, 2013
Pump or bearing problem?
Intermittent grinding metal noise during wash and spin cycles. No leaks, rust or grease splatter. With belt off pump, motor and tub drive shaft all turn by hand with no noise. But only motor will free wheel. Tried spin cycle without clothes or water and it will not make noise. With front of washer removed it is still difficult to say if noise is coming from pump or tranny. Any good way to determine problem?
Lon Cottle
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Sep 26, 2013
Lon Cottle
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
4689
Points
51
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
2 Related Answers
Anonymous
  • 333 Answers
  • Posted on Apr 16, 2008
SOURCE: make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Anonymous
  • 163 Answers
  • Posted on Jan 20, 2009
SOURCE: Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Why does my washer (maytag mah5500bww front loader) make noise during the wash/rinse cycles but not during the spin.?
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
1helpful
2answers
We have a Maytag washing machine, model #HAV2460AWW, rev.10, serial #10359656CR. Just recently it started making a grinding noise that reminds me of a piece of wood jumping up and down against a bandsaw...
we just had the same problem and it was the bearing on the bottom of the pump, then it seized and we could possibly have to replace the motor to because of the load the bad pump put on it, I wish you luck with yours.
4helpful
2answers
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
3answers
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
2helpful
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
1helpful
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
2answers
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
