SOURCE: Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
SOURCE: Changed the IP address on Zhone 6218-I2, can't access browser UI.
Go to start -> run -> cmd.
When the window comes up, type: "ipconfig". The address that says "Gateway" should be the address of the router.
If that is too confusing, try the following combinations:
192.168.0,1,
192.168.0.254,
192.168.1.254
192.168.2.1
192.168.2.254
SOURCE: Zhone 6212-I3-200-0PA, What is the
its usually default:
admin
admin
or
admin
pass
or
admin
(no password)
try them and let me knw how you get on?
SOURCE: My Zhone 1518-A1 modem-router keeps loosing
Its normal for the internet light to blink, it means that its having an activity.
Try accessing the modem GUI (graphic users interface) and then change the WEP key or security key , if the modem-router is not password protected then just reset it.
You can also change the power values on it
Hope this helps
Thanks
Dennis
SOURCE: What is the default username
if you are in IL and on consolidated communications, which just loves these boxes.. try admin/cciadmin
