Apple iPad 32 GB 3G Tablet PC Logo
Unlock ipad - Apple iPad 32 GB 3G Tablet PC
I forgot my ipad passcode and never synced to a computer
I would just take it to a instore mobile phone repair man/or lady usually chinese are great at what they do not expensive .
2answers
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
How can I unlock my iPad?
As a matter of fact, there are a few different ways to unlock your iPad. And using iTunes will be easier. Just follow below steps.
For more methods, check: How to Unlock iPad?
1helpful
3answers
How do i fix my disable ipad
Go to iTunes then sign in, connect your iPad to the PC/Laptop and factory reset the iPad, that is the only way it can be done!
How can I login to my iPad when the passcode isn't working?
You have to reset your iPad. Just follow below steps.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
iPad Air
iPad mini/iPad pro
2. Wait for the process to finish. Then you can set up and use your device.
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
You need to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do a restore:
unlock-ipad-of1o0fkyrymqaiqlgkygvvrr-3-0.jpg unlock-ipad-of1o0fkyrymqaiqlgkygvvrr-3-2.jpg Restore iPad to new factory condition Restore iPad to new factory condition
Ipad air will not unlock
Try below steps to unlock your iPad Air.
2helpful
3answers
How to unlock jailbreak on iPad?
If you prefer a simple yet fast solution to jailbreak your iOS device. You can take a try of AutomaticiPhoneUnlockers.com, it can help jailbreak or unlock as many iPad, iPhones, iPod Touches as you like. Both Windows & Mac OS X are compatible.
1helpful
How to unlock ipad for free
It is possible to unlock your iPad (or other iOS devices) now. And if you prefer an easier way to do the job, see how you can achieve it on your PC or Mac on your own from this website: www.automaticiphoneunlocker.com
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
