SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
