Replased empty ink needed.all show full. cx7400. print page and middle is blank.won/t stop printing. page after blank page. shut off and turn back on and it starts again on its own.son.s printer who is in seattle so its my problem and no expert.
Do you mean your Epson Printer Printing blank pages? The Epson printer printing blank pages due to wrong paper size, outdated printer driver, Empty ink cartridge, dirty print head, improperly installed ink cartridge, and more.
Follow the steps to fix the Epson printer printing blank page issue:
Ā·Restart the printer Ā·Fill the empty ink cartridge and reinstall the new ink cartridge Ā·Update printer drivers. If you have done all the above steps but still the printer printing blank pages.
Epson printer printing blank pages, when you have an empty ink cartridge, outdated printer driver, printer print head missing, improper ink cartridge installed, and more.
Ā·Restart the Printer Ā·Fix the empty and damaged ink cartridge Ā·Clean the dirty printer print head Ā·Update the printer driver
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on
your computer, in your software of choice, or even on your printer, a blank
page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with
your document and ready to print.
Observe your document.
If you see an extra, blank page, you have
created a second page.
To delete the second page, close Print
Preview, go back into the document and eliminate any blank lines in your
documents that you may not need.
You may also find an inadvertent page break at
the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show
Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do
not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print,
within the Print dialogue box.
This is typically done by selecting the
"Print From" option, then entering the page numbers desired.
If your document happens to be ten pages
(without, of course, that final blank page), then enter in the "Print
From" field the numbers "1-10".
This will print only pages 1 through 10,
without an eleventh (blank) page.
hi and welcome to fixya Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Print a diagnostic page
If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
Make sure the printer is on and loaded with unused, plain, white paper.
Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints.
Figure 1: Power and Cancel buttons1 - Cancel button2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page
You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem.
However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed.
Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)1 - Printed by the right cartridge2 - Printed by the left cartridgeNOTE:
If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank.
Step 5: Check ink levelsNOTE:
If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable.
Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color.
Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyFigure 4: Both left and right cartridges almost full
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
