Apple iPhone4 4G iPhone 4 Logo
sherree hancock Posted on Sep 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I delete contacts from phone that were sync with facebook?
Steve L
Level 2:
New Friend:
  • Apple Expert 85 Answers
  • Posted on Oct 02, 2013
Steve L
Apple Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
72824
Points
157
You can do this in Settings --> Facebook ---> un-tick contact
or here
How do I get my original Facebook page back with my contacts after opening a new account?
First, I'm not a Facebook representative (but I am a retired too.)
* Contact Face book support;
* answer from FB:
On Android, this is in the Facebook app under Settings > Sync Contacts. Just set it to "Don't Sync". On the iPhone, go to the Facebook app, click the menu button, scroll down to "Friends", then hit the share button in the upper right-hand corner. Tap "Sync Contacts" and turn syncing off.Jul 2, 2012
*** Following is for information only. ***
* II believe you just need to log into your original Facebook account (using a laptop or your smart phone.)
* You can use the "Forgot password" option if you forgot.
* Once on your original FB account. Check out you friends list. Your probably using the same list for messenger. (unless you used "Messenger" Service long before setting up a F.B. page.)
* Just a note; It's VERY hard to delete a Facebook account. Even on purpose. It's a complicated process that can't happen by pressing the wrong key by accident.
* Check YouTube for "How to Delete Face Book Page for good?" (Once posted on internet. It's on forever.. Remember "Betty Boop?".... Forever.)
Aloha, ukeboy57
tip
How do you Sync Facebook Pictures with Contacts on your Android Phone
<p>Android phones continue to be a group of phone contacts stored on the Google "Contacts" application device, but synchronizes contacts with other services such as Facebook and Twitter to use. This results in duplicate contacts, only some of the information on each individual offer. If you combine the contacts you can sync contact with the image of a Facebook phone contact for quick recognition. <br /> <p><br /> <p>1. Setting up your Facebook account to sync with your phone. Check the configuration of the account "Accounts & Sync Settings section 'of the" Settings "app. Touch a disabled account, select" Synchronize Contacts "to activate it, or tap" Add Account "to the new Facebook account in the phone. <br /> <p><br /> <p>2. Touch the "Contacts" icon in the application menu, or open the phone dialer on the Quick Start section and tap "Contacts" tab. Press "Menu" and select "Display Options." <br /> <p><br /> <p>3. Tap the drop-down arrow next to your Facebook account and check the "All Contacts" box to ensure the Facebook contacts are displayed correctly. You can disable the Facebook contacts to show when ready. Press "Back." <br /> <p><br /> <p>4. Scroll down and tap the contact you want to sync to a Facebook photo. You can choose whether the phone or contact Facebook, but if the two names together last contact will use the name you select. Press the "Menu", click "Edit Contact" option. Press "Menu" and select "Join". <br /> <p><br /> <p>5. Scroll down and touch the second version of the list of contacts. The two contacts together in one item and leave your Facebook picture. Tap "Done" to save the settings. <br />
on Aug 18, 2011 • Google Android
tip
How to Sync Gmail and Facebook contacts/ Phone numbers
<p>Many of the new smartphone with Android operating system, which integrates Google services like Gmail. A feature of the system is the ability to synchronize contact sites such as Facebook friend. Synchronize your contacts from your Android phone will not touch the data available in the online versions of Google apps like Gmail or Google Voice. However, it is available for all applications on your Android phone, the contact list to use. <br /> <p><br /> <p>Install the new Facebook <br /> <p>1. Install the Facebook application. The most Android phones are installed, but not yours. Open the "Market" application, search for "Facebook" and install the application "Facebook, Inc". <br /> <p><br /> <p>2. Open the Facebook application. You will be prompted to enter your Facebook account, using the same email address and password that you use to get online. <br /> <p><br /> <p>3. Select "Sync All" during the setup process for the Facebook Android available in your contact address book to take. You can also choose to synchronize only existing contacts, or not sync at all. <br /> <p><br /> <p>Existing installation Facebook <br /> <p>1. Open the Facebook application. <br /> <p><br /> <p>2. Click on "facebook" in the left corner. <br /> <p><br /> <p>3. Press your phone's menu and select Settings. <br /> <p><br /> <p>4. Scroll down to "Other Settings" and select "Sync Contacts". <br /> <p><br /> <p>5. Select "Sync All" and press "OK". <br />
1helpful
3answers
How do I delete Facebook contacts from my iPhone 6 contact list after IOS11 update?
  1. Go to Settings -> choose "Facebook".
  2. Then switch off the toggle called "Contacts".
  3. This will then delete Facebook contacts from the local address book. Don't worry, because the friends/contacts will remain active on Facebook.
If you already have updated to iOS 11, you will have to remove your Facebook contacts from the FB Messenger app manually.
For keeping additional contacts which are synced from your Facebook data to the Contacts app (iPhone's address book), but hiding them from the main list of contacts, you need to modify view settings.
  1. Launch the "Contacts" app -> tap groups.
  2. Now scroll till "All Facebook" appears and uncheck this item.
  3. Check any other group to make them visible, such as the iCloud, Gmail contacts or any group that may have been activated on iPhone.
  4. Tap "Done" when you're finished.
straight from unlockboot.com
Oct 20, 2017 • Cell Phones
2answers
Why won't my phone sync my Facebook to my contacts?
you need to go into settings on FB and check the box for FB to sync. it wont sync on its own. needs your permission.
Nov 27, 2015 • Cell Phones
tip
Contact Numbers How Facebook Mobile Phone Sync
<p>If you have an iPhone or Android phone, you can sync your Facebook contacts to your phone. Otherwise, if another mobile phone, the synchronization feature of Facebook contacts may not be available. Android and iPhone smartphone users have it easy. With a few taps, you can configure the synchronization feature; the Facebook application handles the import and exports your contacts from that point forward. <br /> <p><br /> <p>Android <br /> <p>1. Put on your Android phone, and go to the home screen. <br /> <p><br /> <p>2. Touch the "Facebook" icon and press the "Menu" button on your phone. Touch the "Settings" from the pop-up. <br /> <p><br /> <p>3. Scroll down to the bottom, and tap the "Sync Contacts" option. <br /> <p><br /> <p>4. Choose what to synchronize. Your options include "Sync All" or "Sync existing contacts." The last option is just to sync contacts from Facebook with people aligned with your "Contacts" app exists. If the person is not there, it will not sync. I want all your Facebook contacts to your phone to get, then you choose "Sync All". <br /> <p><br /> <p>5. Touch the "OK". Facebook will start regardless sync contacts in the background when the application is running or not. Every time your contacts are updated, it will also synchronize the data. <br /> <p><br /> <p>iPhone <br /> <p>1. Turning your smartphone iPhone, and go to the home screen. <br /> <p><br /> <p>2. Touch the "Facebook" icon to start the app, and then the "Friends" icon in the app yourself. <br /> <p><br /> <p>3. Tap the arrow at the top right and select "Sync Contacts". <br /> <p><br /> <p>4. Move the slider to "Synchronize" to "ON" position. <br /> <p><br /> <p>5. Tap the "Sync Contacts" button after reading the disclosure law. The synchronization process should begin immediately, as well as your Facebook friends and downloads their photos to your profile "Contacts" app. <br />
Need to remove pictures from Facebook-Need directions on my Droid Phone.
Hey Jenna lee, i got it to work so here is what i did. It was frustrating so i played with it a little here is the basics of what i did for android
Make sure you go to settings on your phone, then under accounts, click on google click on each email you have for syncing and then uncheck the boxes that say "sync google photos" and "sync picasa web album".
next..
1.I deleted all of my photos off of my facebook (i was going to delete facebook account anyway)
2. i had to uninstall facebook, then re install it again ....and right before it comes on it will ask you too syn contact/photos... select "no syn"
3. next i went to "settings" then "application manager" on my phone ... found the facebook app and cleared the data....
4. then i went to gallery app in application manager and cleared that data too.
5. then i uninstalled facebook again.
6. then i went to "storage" on my phone.. clicked on photos and then deleted all of my photos on there
7. i backed out and went back to application manager to see if my gallery app data was still cleared,.... if not then clear it again.
just make sure you are doing these things .. i was really playing with it, but those are the main places i was deleting at. hope it helped.
hope that it helped
On phone directory why does my facebook friends be on my cell phone. I do not want my friends from facebook on my phone everytime i go to make an phone call. So how do you delete this feature from my...
This has happened because you signed up for Facebook during the initial setup ( when you first powered on the phone ) or in friend stream .
Now you need to go to settings > accounts and sync > click on Facebook and uncheck contact sync from there .
Thumps up if this work ( all the 5 )
1helpful
I cant logout on facebook on my Samsung Wave525.theres no delete button on the "My Accounst"
If you want to log out on face book, go to the top right corner and click on Account. Scroll down to log out and click on it. Very simple.
open my account from main menu, there you should see the text social networks, and your facebook account.
TAP the facebook account and you will see the sync page allowing you to sync your contact and calendar from there.
instead, take a look at the lower left corner. it's a delete button! tap it.
Regards.
1helpful
How to delete the contact belong to our email or facebook on phone book.
To remove "accounts", go to SETTINGS > ACCOUNTS AND SYNC and select the gmail and facebook account you wish to remove.
Alternatively, you can Contacts/Phonebook, press the Menu button and select Settings. You should find the ACCOUNTS options and you can remove the google/gmail and facebook account there. - Need further help? Reply in the same thread with more specific details : tech-avi
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
