SOURCE: I need the manual for Smith Corona SL 480 typewriter
I have a manual...which pages do you need/or what is the trouble..enhanced features...
Elizabeth
SOURCE: Need owners manual:
I have been unable to find a site where you can download a Smith Corona typewriter manual. However, you can try going to Will Repair Service. They carry manuals of every Smith Corona typewriter ever made, and you should be able to find a manual for your particular typewriter there. I find them to be a very helpful and trustworthy typewriter shop.
YES, SMITH CORONA DOES STILL EXIST!
Best of luck to you! :-)
SOURCE: smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
SOURCE: Smith Corona SD 250
1) Move the print carrier to the center of the platen using the SPACE and back arrow.
2) You will see a lever on the right side of the carrier. Pull this lever toward you and
lift out the daisy wheel.
3) Place the daisy wheel into the slot with the characters facing the platen.
4) Push the lever back into position.
5) Press the CODE and = (SETTING) key.
See the user's manual here:
http://www.smithcorona.com/pdf/WS200Man.pdf
