I have seen this several times now. It is usally do to 1 or 2 things that you can try to resolve this. The first issue is that these tablets are very battery eaters and you need to charge it for atleast 24hrs with power cable before you activate it. The USB cable will only keep the tablet charged if u have a good 50precent charge in it first. I have had the WI FI discharge a full battery in 2hrs plug in to the usb. The power adpter needs to be used when u can or it will discharge the batt unless u power down the unit not just let it go to sleep.
Go to the settings tab..then to battery..and u can see what the rate of discharge is ..ie..wifi and wallpaper and idle all can be adjusted to max battery life and make sure you turn it off when u can.
Hope this helps.
Chad Man
