Printer is initialising properly, but when i scan / print something, it shows "LSU ERROR"
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. Laser diode could be bad.
LSU REFERS TO LASER SCANNING UNIT, PLEASE CLEAN THE GLASSES OF LSU, OR REPLACE THE SAME. HAPPY FAXING OMNIPRESENT
Buy a new one.
LSU DISPLY ON SAMSUNG 4521F
You open your cover printer after that you look for cables joint from scanner Box (of print) to board may be it is broken.
LSU error pls riply WebRepOverall ratingThis site has no rating(not enough votes)
Leser Scanning Unit needs cleaning or realignment, I open mine did some cleaning inside and all worked well. call a tech if problem persist.
I had similar issue with the computer.And is being resolved by thebestpcdoctors. Contact for a free PC diagnostics. The toll free number is 8774079229
Essa é uma falha no cartucho, para ser mais exato no fusível do mesmo, ou está sem ou está com um rompido ou está com um muito forte. (Fuse cartridge error)
Call the ASC, the mainboard is malfuntion and need to be replace.
Turn the machine off then on. It worked for me!!
SOURCE: LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
I got this error when trying to print from manual feed.. it seems it doesn't understand there isthe paper.. it's a .... I have also a scx-4100 and it doesn't have this problem...
my printer shows same problem of LSU when i try do Xerox ...what is the prob and wht should i do
Turning off the printer didn't help me. How does this LSU unit looks like, and where is it located in the printer, so I can try to clean it up?
Samsung SCX-4521 give error LSU error when any funtion is selected of the printer. It doesn`t start to print at all. Do any clever gorroo have a solution.
Thanks
ivdm
LSU ERROR AND CANNOT TAKE PAPER FROM THE PAPER TRAY
LSU ERROR shows in display panel Printer are Samsung SCX-4521F
LSU ERROR
i CAN USE THE XEROX PE 220 PRINTER.
TAKE THIS PRINT ERROR IS ACCORED DISPLAY IN LSU ERROR
the xerox product display: LSU error and it can take the paper from the paper tray.
LSU error in Samsung scx
4200
Xerox workcentre PE220
tried printing/copying and it said LSU error
havent tried scanning yet though
THE PRINTER IS NEW, LSU SHOW IN THE SMART PANEL, DONT´ WORK
a have a lsu error on my display of the printer scx-4200
CAN U HELP ME? WHAT CAN I DO?
CAN U HELP ME WITH THIS PROBLEM - LSU ERROR ON THE SCX - 4200 ? I BOUGHT A NEW PRINTER AND IT NOT WORK PROPERLY, IT IS WARMING AND AFTER A WHILE ON THE DISPLAY APPEARS LSU ERROR.
IS THE CARTRIGE RESPONSABLE FOR THIS?
LSU Error in the display panel
