Are you just setting up a new tv or is this just a recent issue with a tv you have had for some time? I did find and interesting tidbit on the plasma tv's I didn't know, with regards to the buzzing noise, http://www.samsung.com/us/support/faq/FAQ00022542/22710/ with regards to the lack of picture, I would recommend that you look over your cords and check your connects, see if you can select input with your remote, if you can see the menu then the tv is fine and you just need to reselect the input that your video or whichever option you require such as cable or sat. If this fails let me know and I will do more research for you
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle.
Source(s):
I just fixed my TV!!!!!!!!
SOURCE: Samsung SP-S4243 has a constant buzzing noise
This is most probably you inverter board making the sound, most probably a bad solder joint, It would be hard for me to help you any further, but if it is a bad solder joint it could be repaired. Most shops no longer repair boards they just replace them.
If you have the knowledge you could do this, but I would recommend it other wise, there is High Voltage to deal with. I hope this helps. Merry Christmas!
SOURCE: hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
SOURCE: my samsung television (hd ready) has developed a
Check the color settings in the menu. It has white balance and color correction that can be adjusted by hand. If you don't know how to adjust the color balance, just reset the color settings or choose a preset color selection (Dynamic, Movie or Normal).
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
