When I start my CPU then my monitor's green light starts with blinking & after 4-5 minutes monitor gets started. I am facing this problem from previous 5 to 6 days. Before 5-6 days, I had formatted my system perfectly. I have faced this problem first time in my life. So i want to know, in monitor does any part get expire after certain time period. Because I have formatted my system before many times but this problem is occurred first time. So I don't think that this problem may be due to format the system. I think some part of my monitor get expired. I want to know exact reason of this problem. I have purchased my system on 30-sep-2006. Please solve my query with proper solution. Thanks!
SOURCE: monitor dosn't atart
Check SDL,SCL Path and It's related parts(Neck board PCB 2 MICOM)
check Output Voltages of SMPS
And also check dry points.
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor
from power and from computer and test computer with different monitor
to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing
led on front of the monitor , and monitor turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or a broken contact, identified an internal fault and kicked in
, starting the flashing light.
If
you are in situation one, then the monitor will reset just unplugging
power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults
that can occurr are a blown capacitor on power board, faulty inverter
board, faulty input board, or a fault on LCD Digital Controller board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: monitor wont power back on,
It sounds like something to do with auto shut down or power saver mode on your monitor. you may have to replace the power supply in your monitor.
It could also be the VGA cable or the VGA connector bent pin.
Step through the menu to see if there is an option to disable auto shut down.
Hope this helps
