Search Results for ORANGE 5 AND GREEN 1
<<Previous 30
results Next>>
1.
Power
light (or Alarm and Power lights) alternate(s) between orange and green
After long green flash, there are 2
or more alternating orange and green flashes. There may also be a Service Error
message on the computer screen.
2.
Alarm
/ Power light flashes orange 11 times consecutively (Automatic Print Head
Alignment Error)
3.
Alarm
/ Power light flashes orange 2 times consecutively (Load Paper / Paper Feed
Error)
4.
Alarm
/ Power light flashes orange 3 times consecutively (Paper Jam Error / Cover
Error)
5.
Alarm
/ Power light flashes orange 4 times consecutively (Out of Ink Error)
6.
Alarm
/ Power light flashes orange 5 times consecutively (Print Head Error)
#1 & #6 seem to be as close as I can find:
here is the page (Below) if you just put the error in the space provided.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
SOURCE: 3 yellow flashes, then 1 green on a Canon PIXMA
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
SOURCE: I have a Canon Pixma
Follow these steps to reset the printer: 1. Turn the printer off with the Power button (if available). 2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) . 3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared). 4.
SOURCE: my Canon printer ip4000 power button keep flashing
It may indicate a printhead error. Look at the followng instructions at the Canon website:
