Repar database file.this is a function inside the camera menu. If database is corrupt because of erased files,like photos or videos deleted from a pc, then at backing up is trying to locate lost files. Remeber. Repair data base files. Or "repair DBF" inside menu.
In an earlier post I had written about how to create an invisible folder. That’s a method to create a merely invisible folder with no real protection.
Now, here we will see how to create a folder that will not just be invisible, but also require a password to reveal it and open it. The best part is that you don’t need any special software to do this. Just plain old Notepad is all that you need.
Here is the code that you need:
cls @ECHO OFF title Folder Personal if EXIST “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” goto UNLOCK if NOT EXIST Personal goto MDLOCKER :CONFIRM echo Are you sure u want to Lock the folder(Y/N) set/p “cho=>” if %cho%==Y goto LOCK if %cho%==y goto LOCK if %cho%==n goto END if %cho%==N goto END echo Invalid choice. goto CONFIRM :LOCK ren Personal “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” attrib +h +s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” echo Folder locked goto End :UNLOCK
echo Enter password to Unlock folder set/p “pass=>” if NOT %pass%==pwd123 HERE goto FAIL attrib -h -s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” ren “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” Personal echo Folder Unlocked successfully goto End :FAIL echo Invalid password goto end :MDLOCKER md Personal echo Personal created successfully goto End :End
Now here is what you need to do:
Just copy the above code and paste it into Notepad. Save it by giving it any name you choose. Assuming, the file is called secret.txt, change the extension to ‘.bat‘ so that the new name becomes secret.bat. What you get is a batch file. You could actually save one step by saving the file in Notepad directly as secret.bat by enclosing the file name like this: “secret.bat” . This batch file is the one that you need. You can edit this batch file to change the folder name and the password. To change the name of the folder that is created, change the ‘Personal’ (in bold in the above code) to any another name you choose. Likewise change the ‘pwd123′ (in red in the code) to anything else.
Now let’s see how to use it. Place the file in the location where you would like to create your protected folder. Run the batch file by double clicking on it. This will create a folder named Personal in the same location as the batch file. You can now open this folder and place any files in it. Once you are finished, run the batch file again. You will be asked whether you want to lock the folder. Entry ‘Y’ (for Yes) and hit Enter. The folder becomes invisible. To retrieve the folder, run the batch file again. You will be prompted to enter the password. Enter the password, hit enter and voila! the folder appears.
Important: The batch file acts like a key to open the locked folder. So once you have created and locked a folder, do not keep the batch file in the same location since anybody can open the batch file and view your password. So I would suggest that you keep the batch file in a separate and safe place or better still keep it on your pen drive or flash drive. That way when you want to open the folder just copy the batch file to the location where you have your protected folder and run it.
Do remember that the above method is not intended to act as a substitute for the numerous free and commercial softwares that are specifically designed to provide security and encryption to your data.
Update: I got comments saying the code does not work. Of course I did check it before posting it here. But I have identified the problem. The problem is with the straight double quotes used in the code in this post. Once you copy the code you would also need to change each of the double quotes with your keyboard double quotes. That might seem a lot of work for some. So I thought it would be easier to give away the batch file itself. You can download the file here. (Use right-click and ‘Save Target as’ or ‘Save Link as’).
Download and install pc kies for samsung,connect your cell phone with your pc,with wired usb.Your computer will recognize your cell and you will follow instructions what to do.
To transfer pictures from samsung phone to computer via usb cable, your best choice is using pro samsung mobile manager tool. With its help, after connect samsung phone to computer, you can directly access pictures on samsung phone and transfer them to computer. How to Transfer Photos between Samsung and Computer
Here are my recommendations for a successful data transfer from phone to PC and vise versa :
Ensure that the memory card is installed in the phone and set it as primary storage instead of the phone's internal memory.
Connect the phone to the LG data cable and the other end goes to the computer's USB port.
Do not use the LG Suite for this as the computer will recognize your phone's memory card as external drive. If LG Suite is installed, you may delete it first then move back to step 1.
This will enable you to drag and drop stuff from your phone to computer or vise versa.
If your camera's memory is structured as most, you can treat the internal memory like any disk drive.
If you have a PC with Windows, plug in your Sony via the USB port, go to 'My Computer' select a disk drive with a later letter than C or D and open it as you would any other drive.
You may have nested folders requiring that you open several folders in succession.
You will recognize having arrived when you have a bunch of individual files shown in Explorer with the suffix Sony uses (commonly .jpg) and you canmanipulate them as you would any other files, including deletion.
Answer:what
you do is you press the play/record button on the left side of the
camcorder when it is open to get to the videos. then you use the laser
touch operation to scroll to the video you want to delete. then, right
under the screen there should be 5 buttons. the one to the left of the
menu button has a picture of a garbage can looking thing above it. just
press that and then press yes when it asks you if your sure.
