Question about Hoover Nextra HNF 3157 Front Load Washer
Have this washing machine need an instruction manual to check Programme details and options
How to return temp set to programme norm
PDF]Washing Machine - Samsung
www.samsung.com/us/pdf/wf218_manual.pdf
Samsung Electronicsto read this manual to take full advantage of your Washer's many benefits and ...Warnings and Important Safety Instructions in this manual do not cover all possible conditions and ..... per hose and install each fill hose to the water valve. ... Press the button repeatedly to cycle through the different water temperature options.
[PDF]User Manual - Indesit
Jan 16, 2016 | Washing Machines
What may be causing my washing not to finish the washing cycle
If you think your washing machine may be faulty, check the following points before calling a Service Engineer. These checks could prevent a charge being made for the Service man's visit if the machine is found to be in perfect working order.
Initially check the filter on your washing machine and clean if necessary, your manual should detail this procedure.
If your machine will not start or complete the programme, check:
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
If water will not enter, check:
  • The hot and cold hoses are correctly connected to the relevant caps and that these are turned on.
  • That a suitable programme has been selected.
If water will not drain, check:
  • That the outlet hose is not kinked or raised more than 40
Oct 22, 2014 | Zanussi FS1455W Front Load Washer
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
Mar 24, 2013 | Washing Machines
I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200 XC6 WASHING MACHINE FX1265W TO ENABLE ME TO IDENTIFY THE DIFFERENT PROGRAMME SYMBOLS THE PRODUCT NO.IS 91479270300 TYPE F6857648 CAN YOU HELP
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Nov 29, 2009 | Zanussi Washing Machines
Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Apr 21, 2009 | Washing Machines
Neff W4380X1 LED 01 appearing
This is a water supply fault. Check that the hoses at the back of the machine are not squashed and check to see if there is water getting into the machine
Aug 31, 2008 | Neff W4380X1 Front Load Washer
Open Questions:
See all Hoover Nextra HNF 3157 Front Load Washer Questions
Hoover Nextra HNF 3157 Front Load Washer Logo
22 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
