AT&T Blackberry Curve 8300 Smartphone Logo
Posted on Apr 20, 2009
Error Code 0x80040fb3 - Blackberry
I have a Blackberry Curve with Sprint. Everything was wiped out and reset last week. Now I cannot get the Outlook Contacts database to synch with the Blackberry desktop software. I recieve the following error code: 0X80040fb3.
I have done everything recommended...clean uninstall and reinstall (several times), checked every single record (all 774 records twice!) for errors in the first and last name fields and company fields. I deleted all photos from contact records and have no attachments. Please help! Thanks.
  • davidsonacct Oct 26, 2009
    Thank you; however I no longer have this product due to the problems it caused me.
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Aug 03, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
14442
Points
40
Use this
http://www.blackberryworld.eu/downloads/JL_Cmder%20v1.9.1.zip
Install
Connect USB
Select option 4
Reinstall OS
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1025
Points
0x80040fb3 i have a problem to syncro outlook with my BB CURVE I GET THIS ERROR MESSAGE
1helpful
2answers
How can i unlock my blackberry 8530 sprint
You need blackberry 8530 unlock code for sprint network, and you can get that blackberry unlock code from sprint provider. Sprint will takes you some charge for that code and will delivery the code in a couple of weeks. You also can buy unlock code from third party sites and you just need to wait a couple of minutes for that code.
I HAVE A 8350I BLACKBERRY CURVE LOCK TO CARRIER SPRINT IWOULD LIKE KNOW IF CAN BE UNLOCK
You can unlock your blackberry network using blackberry curve 8350i unlock code for sprint network. That code will allow your blackberry to use any sim card from other network and you can get blackberry unlock code from sprint or third party sites.Both of them will take some charge, but third party sites have lower price and quick delivery service rather than original network provider.
3answers
I have the blackberry curve 8530 for sprint and I want to switch it to the verizon network, how can I go about doing this?
You just have to unlock your phone totally and permanently from other networks so you switch to Verizon network. You can do this by purchasing the SPRINT BLACKBERRY CURVE 8530 unlock codes from a SPRINT BLACKBERRY unlock code provider. This way, your phone will be 100% SIM lock free..
3helpful
2answers
I forgot my Sprint Blackberry curve password
you will have to enter the password incorrectly about 10x for it to reset but you will lost all data on the phone.
1helpful
2answers
How I can unlock a Blackberry curve?
you can't ... sprint has no GSM card.. it's all imbeded into the phone... you can only use the Blackberry Curve with AT&T and T-Mobile or International if the phone is unlocked. You can't unlock the phone for Sprint
Error 0x80040fb3
Typically its caused by a contact not having a FIRST NAME, LAST NAME and COMPANY NAME. (don't confuse FIRST NAME and LAST NAME with FULL NAME, they're not the same!!)
Do an advanced search in Microsoft Outlook to find contacts with blank First Name, Last Name, and Company fields.
1. Open Contacts in Microsoft Outlook.
2. Open the Tools menu.
3. Select Advanced Find from the Find submenu.
4. Select the Advanced tab.
5. Click Field.
6. Select First Name from the Frequently-used fields submenu.
7. Select is empty from the Condition list.
8. Repeat steps 5 through 7 for Last Name and Company.
9. Click Find Now.
Any contacts you find as a result of this need to be modified to include a first, last or company name (not all 3, just one of the 3)
By upgrading to DTM 4.2.2 or higher, that problem should be ignored (skipped), so if its still happening, I'd first go through the steps listed in that link above.
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11366&sliceId=SAL_Public&dialogID=39575283&stateId=0%200%2039577061
please rate this solution.
Thanks for using FixYa.
Blackberry Curve & Outlook 2007
I've had a few clients with this issue. I have used these steps from RIM. Try it and see if it helps.
Here’s what you need to do:
1. Uninstall Desktop Manager
2. Remove any references on your registry and on your C drive program files and users to:
a. Blackberry
b. Pumatech
c. Research in Motion
d. RIM
e. Desktop Manager
3. Disable the UAC (User Accounts) on Control Panel-Users
4. Get a command prompt and type regsvr32 atl.dll (enter)
5. Reboot
6. Make sure that when you re-install you have absolutely no SpyBot, Virus, Spam guard or the like running.
7. Reinstall Desktop Manager (version 4.2 SP2)
8. If you get an “Error 1904….Lotus Notes…” Ignore it
9. After you do all this, it should work
980helpful
7answers
How do i reset blackberry curve 8330 to factory settings
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
2helpful
Reset email account
If you have noting important in the Blackberry you can get the email account and everything else removed by peforming a security wipe.
Go to Options / Security Options / General Settings. Once here - press the menu button (the one with the BB logo to the left of the trackball) and select Wipe Handheld.
To get rid of the unknown error, you will need to uninstall the Blackberry Desktop software. When you do this, make sure that you have the uninstaller delete the user settings, too. Then reinstall Desktop Manager 4.3. See if that helps with the syncing, too. This solution solved the error problem for me, so I hope it will work for you.
If this does not solve the syncing problem, then post back here again and we'll look for another solution. Sometimes a .pst file repair will help.
Top AT&T Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
