Question about Asko W640
On my W640 Asko washer, the little plastic tab on the door that locks into the machine snapped right off. I'm wondering if I can order a new door and install myself?
Anonymous
SOURCE:
Anonymous
  • 8 Answers
SOURCE: workshop manual
type in manuals on your browser bar and a list of sites will come up click on one,type in your details and you should get a pdf file to download your manual, good luck
Posted on Jun 07, 2007
prem mathew
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
Ian Greenland
  • 351 Answers
SOURCE: Asko W640 Front Loading Washing
may be carbons in motor and or board
Posted on Aug 27, 2008
Anonymous
SOURCE: Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Posted on Feb 27, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
I have the parts but need the instructions to install a new lock on my Asko frontload Washer/Dryer WD22M19.
Disconnect power then remove the clamp that holds the door gasket to the outer lip of the door opening. Once the clamp is off, peel the door gasket off near the door lock. Remove the screws securing the door lock to the front panel and take the lock out of the machine cabinet. Transfer the wires to the new lock then install it into place. Put the door gasket over the outer lip of the door opening and secure it with the clamp to complete the repair.
Oct 25, 2010 | Asko WCAM1812 Front Load Washer / Dryer
Door latch switch failure
no you need to replace the door lock assy
Jun 13, 2010 | Asko W6441 Front Load Washer
We have a problem with our W640. The power shut dowm every time we put the contact in, and we cant open the door bacause of the power. is there any buttom i can push? and were is it?
You can open the door manually: Open the filter flap at the bottom left of machine- you will see a red loop attached to the machine by a screw- remove this screw and pull down on loop- door will open. If you go to www.asko.com.au, click on "customer care", then "manuals", and type in "W640" in the "Search product" box, you can download the entire manual for your machine. Chapter 13 has picture showing how to manually open door. However, if the machine is tripping the power when switched on, you obviously have some electrical fault in machine, which will require the attention of a technician. At least you can get the clothes out though!! Happy fixing!!
May 11, 2010 | Asko W640
Hi, I'm housesitting for a friend of mine and I can't get their ASKO 5250 series washing machine to unlock to get my clothes out! It's been stuck for 2 days. HELP!
If the door switch is faulty, you can manually open the door.
Get a flat screw driver or butter knife, open the little door on the bottom left of the machine, from right to left.
this is the lid for the water pump filter. You will see a red plastic ring which is normally screwed on to the machine with a philips head screw. Unscrew the ring from its position and pull down until the door pops open.
Good luck.
Ash
Oct 21, 2009 | Asko W6021 Front Load Washer
Mar 10, 2009 | Asko W640
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Sep 11, 2008 | Asko W640
Jun 11, 2007 | Asko W6021 Front Load Washer
Workshop manual
Jun 05, 2007 | Asko W640
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
