Linksys Cisco Small Business WAP4410N WirelessN Access Point  PoEAdvanced Security (S7271261) Logo
Erica Grace Posted on Sep 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Accidentally reset my WAP4410N and do not have the pin number to reinstall can you help me figure it out?
Justin
Level 3:
  • Linksys Master 2,072 Answers
  • Posted on Oct 03, 2013
Justin
Linksys Master
Level 3:
Answers
2072
Questions
0
Helped
431759
Points
5629
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
What is default IP of CISCO WAP4410N WIRELESS ROUTER
Hello Anonymous,
The default IP address for the router you are asking about is 192.168.1.245.
The user manual direct from Cisco can be found at the link below.
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
Take care and have a wonderful night! -Alex K
1helpful
Configuring cisco wap4410N
Configuration? What type of configuration / settings would you like to know? Anyhow , just use the link below and it will redirect you to the page of your Cisco Service Manual, where you can see the complete image instruction /setup / configuration of your cisco wap4410N
I am sorry , for the answer that I provided . Since I dont have an idea for the configuration that you needed much better if your going to use the link that provided because its very helpful thanks
How can I get a PIN for a Cisco WAP440N W-less access point?
Here is a link to the manual.
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap4400n/administration/guide/WAP4400N_V133_UG_Rev_B_web.pdf
If this is a device you received used, You will want to follow the factory restore procedure.
I hope this helps you out. Please comment if further assistance is needed.
Accidentally scratched off pin from boost mobile card
yes. I can't figure out the numbers to my card and it has 35 dollars on it.
My cisco wap4410n won't let windows 7 connect
Dear Romo
i have had lot's of problem with the WAP 4410N
the usual solution was to reset the Access Point
and in some case you have to reset it to factory default and set it up again try change the channel of change the location of the Access point for testing only
yesterday i face a problem with WAP4410 that the laptop gets IP but smart phone /tablet doesn't connect stack when getting an IP with static IP the devices connected
So what i did ,I went to the market and buy a new AP NOT Cisco brand
Cisco devises i lost truest on it
Abdullah Al-Ahmadi
System and Network Eng.
4helpful
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
