SOURCE: enter the switch configuration
page 22 of the 3com user guide for your switch talks about how to use the console cable and how to connect to your pc, I included the link below for your manual, if you don't have it:
http://support.3com.com/infodeli/tools/switches/baseline/3Com_Baseline-Switch-2916-2924_User-Guide.pdf
SOURCE: inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
SOURCE: How do I connect to 3com officeconnect dual speed switch 8 plus
on a mac u have to go to finder, applications, uttility, network utility and in there under the info tab there is a drop down. in that drop down you have to choose network interface (en1) AND IT GIVES YOU THE IP ADDRESS
SOURCE: Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
SOURCE: i am looking for 3com 4228g default ip address
It depends what device on your local network it is
It may be 192.168.1.1
or 192.168.100.1
You may have to do a network scan and locate its exact network IP
The default IP address of the device, depends on the status of the network where the device resides, but if the device is not connected to the network, or no DHCP server exists in the subnet where the device resides, you can get the default IP address of the device on the label on the right of the device rear panel.
