My child pushed and hit the tv screen and now we have lines going through the tv picture. its most noticable when brighter colors are on. anything going to fix this
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
SOURCE: 42' Sanyo Flat Screen Tv
An lcd screen cannot be repaired, only replaced and for a cost around what the went for when new. You can try looking on ebay or craigslist for the same model and swap parts. Had it happen to me, it sucks. Also your home owners insurance should cover it. Sorry thats all the help I can be.
SOURCE: T.V. won't allow me to adjust color and sound...
Chepe_77,
You are absolutely correct. The reason why you cannot change your audio and video settings are due to the fact that you are in "Dynamic Fixed". Which is one of your many av modes. Av modes are different preset color settings and dynamic fixed is the only one that will lock your settings. Best Buy set it that way so that people could not just come by and alter the settings on the unit. AV modes are on all sharp lcd products and even though you have the wrong remote you should have an av mode button on the remote that came with it. Try pressing the av mode button and see what happens. When you press the av mode button, you will see your av modes change at the bottom of the screen. However, the issue still remains that you have the wrong remote. So there is a chance that you may press the av mode button on the remote that you have, but it still will may not work ONLY because you have the wrong remote. If the remote you have does not work, I GUARANTEE that pressing the av mode button on the proper remote will take care of that. If you dont want to purchase the remote from sharp, www.partstore.com is a good place. Good luck to you
SOURCE: picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
