HEWLETT-PACKARD Color LaserJet CP5225 Printer Logo
A
Anonymous Posted on Oct 01, 2013
How to replace dc controller board on hp cp5225n
Ed Mac
Level 3:
  • Master 731 Answers
  • Posted on Apr 06, 2016
Ed Mac
Master
Level 3:
Answers
731
Questions
0
Helped
252421
Points
2239
Remove 5 screws from rear cover and remove it
Open the right door to expose 2 screws holding right cover, release tab and remove Right Cover
disconnect 22 cable connections and 6 flat cables from the DC Controller PCB
Disconnect 3 intermediary wire connections and release the cables from the cable guides on the top and right sides
remove 4 screws from the 4 corners of the DC Controller
Remove PCB
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
Out Bin Full
I share a informative link please visit and read it.... HP Support document HP Support Center and HP Printer Support
Thanks,
1helpful
3answers
How to replace DC controller board
HP Service Manual Library
Download the manual here, this is your best option and will show you step by step.
Error 68.2 on HP laserjet P4015n
If you are unable to solve this problem using above mention solutions then you can try this one. Open all covers and then detach the DC controller board that is shown In picture below. it is the back side of DC controller board.
With this DC controller board you can see another small circuit bard that is attached with DC controller board with a white (ribbon) cable. I found two printers with this error when I examine the board I found that the thin print wires are broken as shown in the following picture. I have to connect these wires with soldering and now it is working fine.
If these printed wires are ok then you can check the ribbon cable .check all connectivity with Multimeter.
First you solve this problem with software.
Then try to find disconnected wires or dry soldering on circuit board.
Last you change the Dc controller board because the problem is in surly in DC controller board.
1helpful
Need instructions on how to replace the DC controller on my HP3505dn printer
Remove formatter assm, remove back cover you can see above snap shot of dc board, discnnect all the connectors gently, remove screws take it out...Replace another one.. But you are not mentioned why you are going to replacing the DC controller..
My customer explains that water got poured into her HP LaserJet 4200, now it won't power on, no display, no engine noise, nothing. I have replaced the large power supply on bottom, and the fuser,...
I have had this problem before and replacing the high voltage board ( that is the large board situated under the printer ) fixed it. However if you have replaced this board then I would agree that the water also took out the DC Controller Board.
The fuser probably did not need to be replaced.
3helpful
Hp Cp6015 printer has 50.7 Error code fuser has already been replaced
this error could be caused by the new replacement fuser or your DC controller board. I would return the fuser that you just put in for another first. And if the issue is still there then try a new DC controller board.
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
