I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Regarding thread bunching up underneath the fabric on the Singer CG -590: my husband just discovered that I had my thread incorrectly wound through the first thread guide. It was allowing too much slack in the thread. I missed the piece that is described in the manual as follows: "Lead thread passing it first under the thread guide. Next through the upper slot, leading the thread to the right and around."
Thank you so much Ken! Problem immediately solved. Blood pressure has gone down (just kidding)!
Thanks again.
I have the same problem with my singer 3810. The thread loops up under the fabric and I don´t really know where I should tighten the screw??
I bought a CG590 the otherday and having trobles back stitching , the machine goes fine forward, but reverse the material will bunch up.
Is there anyone else having this problem and fix it, or any help oout there. Thanks Lydia
I have
I have the same problem with thread bunching up on the underside of the fabric. I've rethreaded the machine several times, also the bobbin. No luck.
I have a Singer CG-590/
We are having the same looping problems as the others.
PLEASE HELP!!!!!!!!
proper way to load bobbin
