SOURCE: GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
SOURCE: Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
SOURCE: battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
SOURCE: GE Simon 3 Alarm: Reseting Dealer and Installer Code!!
My problem is related. It appears that my Option 08 is ON, meaning the memory clear to factory defaults will not clear my (unknown) Dealer code/Utility code 1.
There must be some way to override Option 08.
My guess there is a jumper pair on the circuit board, but I can't find any description of the jumpers.
SOURCE: sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
