You can easily resolve your issue. You just need to follow some steps which you can find here. Source: http://www.toshibasupport365.com//blog/fix-toshiba-cooling-system-error/
If you have purchased the optional Fax feature, the e-STUDIO Fax Option. Then might be the Client CD-ROM consists of a TOSHIBA e-STUDIO28/35/45 digital copier, because with this it will show an error of 0xc0000185.
How to Fix Toshiba Error 0xc0000185 Call Now 1 800 505 1746
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
SOURCE: Thoshiba E studio giving the Total Counter 220320
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
SOURCE: i have a e-studio 352
you driver is not working order, you could download in the http://mba.toshiba.com/support/index.jsp, you only have to write or select the model and download it.
Good luck.
SOURCE: What does error code e010 indicate on the Toshiba
open the side door >> you find any paper?? remove it
else you need to change the jamming sensor
