Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Sharp aquos how to disable the osd - ViewSonic N2750w 27 in. HD-Ready LCD Television
Disable speakers aquos
In the audio setup screen , direct the sound to external. If you're using an optical cable then direct the sound to optical
Feb 17, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Hulu plus problems with my Sharp TV
If you are trying to play Hulu from a cell or PC, the HDMI is automatically disabled. As far as I can see, Hulu is not available as a Sharp Aquos app either even with the latest firmware. I have to use my older Vizio smart TV. Go figure.
Nov 23, 2012 | Sharp Televison & Video
Need to turn timer off on sharp aquos lcd tv
Using your Sharp Remote go to Menu,Find Sleep or Timer Function Disable
Dec 29, 2011 | Televison & Video
With my SHARP AQUOS, while in 1080, my tv pic stretches entirely to the right. Half the pic is unable to be viewed.
On ,the OSD board,or in the menu, there will be a auto set ,that will let the picture to fit the screen.
Jul 06, 2011 | Televison & Video
I have a TV SHARP AQUOS LC-32D44U model, does not turn on instantly, when I turned on the TV, get flashing the POWER and OPC LEDs; I turn on and off several times until it turns on normally, please I need...
the Caps (capacitors) have one foot in the door on your PSB-Power Supply Board. Pretty soon you'll get no OSD-On screen display and be left with a blinking fault LED Code. Caps are cheap and easy to replace with Intermediate skill. Or pull the PSB yourself and take to a PC repair shop that solders at board level to replce the UF Caps that are going bad. If you need instructions on how to do this let me know.....
Jun 18, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Images go suddenly darker
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
Jan 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
157 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
