Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer lde 313
Electric dryer makes clicking sound but wont start, in all cycles. older model but great shape, never had any trouble before this.
    Genius:
  • 1,198 Answers
Check the belt.
Posted on Apr 28, 2009
6ya staff
SOURCE:
My Maytag dryer, model LDE 712, seems to complete the cycle in all selections, but does not stop when finished. This is so in both the automatic and timed selection. Advancing the timer manually to the...
Most likely the timer is bad. The contacts in there get badly carboned up/pitted over time and will sometimes not make contact when they should. You could try using a small nail file to clean them. Only problem is there are quite a few in there. It may be more cot efective to get a rebult unit.
Aug 24, 2014 | Maytag Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
L have a older maytag lde 410 the drum is hard to turn after the belt came off can you help us please
here is a descent website, Hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Maytag MDE8757AY Electric Dryer
Maytag Dryer Model #LDE 4916 ACE. Dryer won't start
Sorry, no reset button. If it ran a bit without the belt, it may have overheated and blown one of the thermal fuses. You can find schematics and diagrams at
www.appliancepartspros.com
Good luck.
Mar 15, 2010 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Maytag model
You really need a volt / ohm meter to check for Continuity & VoltsIts well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity they have to be replaced
Oct 11, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
372 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
