Here is your service manual:
http://elektrotanya.com/peavey_pv-2600.pdf/download.html
Scroll down and find link on this page "Get Manual" and click on that. You can only download two manuals a day unless you are registered at the site.
Lots of luck on this one... there are 16 transistors per side that can all fry... Fail to weed out all the failed ones and it immediately blows again. Use a 150 Watt incandescent lamp in the hot side of the power input to act as a current limiting fuse while testing so you don't blow up more parts. When the unit is good to go, the lamp will go out when you power it on after briefly lighting. This is likely an expensive repair.
