Ricoh Aficio AP3800C Laser Printer Logo
A
Anonymous Posted on Oct 02, 2013
Sc220 ricohmp4000? - Ricoh Aficio AP3800C Laser Printer
SC220-04 ERROR ON RICOH MP C4504SP
It is caused by Resetting / Memory Clear.
https://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/137996-mp-c4504-sc220-04-after-all-clear-performed.html
1. Turn the main power OFF/ON.
2. Check for condensation on the LDB.
3. Reconnect the connectors between LDB (Synchronizing detector board)
and IPU.
4. Replace the LD unit.
5. Replace the IPU
6. Replace the harness between LDB (Synchronizing detector board) and
IPU.
https://www.google.com/search?q=SC220-04+ERROR+ON+RICOH+MP+C4504SP
2answers
What is error code SC220
http://terraofficesolutions.com/forum/index.php?topic=50.0
SC220 Ricoh MP2500
I got an new email server and it has worked for a week but now I can't get any new information on facebook
Sc220 aficio mp 7500
hi
check the main switch of front door
Error code SC220-05
SC 220: Laser synchronization detection error
possible causes :• Laser synchronization board
connector loose, broken, defective
• Laser synchronization detection
board is not installed correctly (out
of alignment)
defective
• IPU defective
1helpful
My Ricoh aficio 3800c keeps stalling with error code sc220-4. How do I fix it?
Hi. The SC220 issue is a known one on the 3800c. It's a firmware related problem, and the code, which points to the synchronizing detector boards, is erroneous. You can read more about it, and possible ways to avoid it here.
Updating the firmware to get rid of this problem is not an easy job.
4helpful
Error code SC220 for ricoh spc811dn what do I do?
sc220 is a laser sync error. You'll probably need to either replace the laser sync board or the laser diode itself, so you may want to contact a local service technician, as both of these components are internal and can be slightly tricky to get to.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
