Question about Sony KDL46S3000 46 in. LCD HDTV
Dish Network Channels Work but Local Television Channels Do Not
I just bought my Sony-Bravia television in March and cannot get all of my local channels. I do have Dish Network and all the channels come in fine, but when it storms and Dish Network is down, I switch to local television stations to watch. My paperworks shows that I do not have to have a converter box, however, when I autoscanned my new TV I could not receive my locals - so I purchased a converter box. Even with the converter box I can only pickup one local out of the 8 that are available here in Arkansas.
Can anyone help?
  • 3 more comments
  • mstarks818 Apr 21, 2009
    I have an outside antenna that I use to watch my local stations and it is connected to my TV.
    If my Dish Network is not working I go through my input button to TV to watch my local channels. This is how I watched them when I had my old 32 inch Sony when Dish was out due to storms.
    It was my understanding that once local television stations went digital that you would not be able to pick up those channels unless you have one of those converter boxes. That's why I decided to buy a new television because I was told that with the newer televisions they were already equipped with a tuner to receive those digital stations and that I didn't need a converter box.
    When I connected my new TV and ran the autochannel scan, I receive all my DIsh Network Channels including local ones. However, when I go through my input button to watch regular TV all I get is a snowy picture.
    So I went back to where I bought the TV and the salemans said I still needed to buy a converter box. So I bought one and followed the instructions to install. I went to Channel 3 and hit the channel scan button. It scanned for about 25 minutes and only found one channel out of the 8 that are available for my area.
    Does living in the country make a difference?
    I'm at work right now and do not have my Model number with me. I will bring it with me tomorrow. Thanks Crikett
  • Anonymous May 08, 2009
    We have the same problem about receiving local channels prior to upgrading to a new tv and dish. We were told that we would get those local channels we had before and then after we got the dish in we were informed that we couldn't get those local channels via the dish because the FCC limits the local channels and the area that those original local channels are transmitted. We received the original channels for over 30 years on a Channel Master antenna and now we can't get them because of the upgrade to digital. Now we have local channels from another area of our state that we don't even frequent. Good luck getting this solved. Just another way for the Government to control our lives.
  • Jim Krause May 11, 2010
    First- Give me your Model number. If your set does not have an ATSC tuner in it then it will not receive the digital stations without a converter box with over the air stations. So post your Make and Model number for me.
    What are you using for recepton for your local channels?
  • 30 Answers
Do you have an antenna hooked up? You'll need one hooked to your converter box because the digital signal is so much more difficult to tune in to. This may help:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Posted on Jun 02, 2009
2 Suggested Answers
6ya staff
SOURCE:
Cary Leonardt
  • 304 Answers
SOURCE: hdtv qam tuner
More often than not the problem is with the Cable co. They ALWAYS blame the tv. I have had many many problems with the signal quality coming from that co. Here is the most likley cause. The cable signal is probably very Weak. This can be caused by a weak signal coming from the cabls co. or a bad cable inside your home. The age of the cable can effect the signal quality.Note: The cable co is only required to provide a Digital signal. Some companies allow free HD signals and some charge for that signal. The correct approach to this issue is to get with the Cox and ask the if they provide free Hd channels without a box. If they say no then you will have to get a HD cable box to watch HD programs. Themn if they say yes then you need to ask them to send out a tech and test the signal coming from the Head End all the way to your set. If the signal flucuates then you will get inconsistant scanning results.
Posted on Jul 17, 2009
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
HDTV no over the air signal.
No... Andraade11,
There is nothing exclusive of using a HDMI port...
you can have it all.
You are still able to switch right back to your old configuration...
I believe you merely need to step through your
"SOURCES"
Unless Dish us incredibly behind the curve
they used a HDMI to bring their signal to your set...
and add ($$$) a LOCAL "OPTION" into
their feed... but if you ALREADY had an antenna
hooked up... you should be able to switch right back to that source... or a VIDEO PLAYER obviously IF you have one)
and/or a SECURITY screen
(if you have a compatible camera or server)
Etc. etcetera...
Carnac the Magnificent
Apr 05, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Screen too big for mitsubishi black diamond tv
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
Dec 01, 2008 | Sony BRAVIA KDL-40V3000 Television
No satellite
probably fried the lnb on the dish or the receiver itself
May 07, 2008 | TruTech PVS2119 19 in. LCD Television
One T.V. snowy on Sat., clear on local channels, others are fine?
if you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Apr 16, 2008 | DISH Network 311 DTV Receiver
2006 Sony KDL-V40XBRI
sony bravia lcd troubleshooting
https://www.google.com/search?client=ms-android-att-us&ei=O8blWLC3CIvKjwTi54DIDg&q=sony+bravia+lcd+troubleshooting&oq=somy+bravia+lcd+troubl&gs_l=mobile-gws-serp.1.0.0i22i30k1l5.154.16000.0.16940.47.34.1.3.3.0.1404.11353.0j9j4j5j2j2j3j2.27.0....0...1c.1j4.64.mobile-gws-serp..26.21.7197.3..0j0i7i30k1j35i39k1j0i131k1j0i67k1j0i10k1j0i13k1.Ar_4YkwTSbY
Apr 06, 2017 | Sony BRAVIA KDL-46V3000 Television
NO SOUND ON NEW TV
What kind of Connection do you have coming from the Dish receiver to Your New Sony Bravia TV. This is very important information.
Best regards
CircuitCity
Dec 05, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KDL46S3000 46 in. LCD HDTV Logo
4,076 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
