Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair Logo
Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tool light is blinking on my electric wheelechair. why?
  • Anonymous May 11, 2010
    how many blinks?
  • patricia
    patricia May 12, 2014
    3 red and 4 yellow
Anonymous
Level 2:
  • Expert 103 Answers
  • Posted on May 26, 2009
Anonymous
Expert
Level 2:
Answers
103
Questions
0
Helped
41076
Points
147
How many times is it blinking?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
3966
Points
6
9 flashes is a communication fault. The joystick cables might be bad.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2841
Points
Pronto m51 tool light blinks 9 times i charged battery but it won't move
  • Anonymous Aug 08, 2009
    what is wrong with my chair please
The prnd lights on the dashboard keeps blinking even when the car is in gear
If the PRND lights on the dashboard of your 2018 Kia Forte LX are blinking even when the car is in gear, it suggests a potential problem with the transmission or shift selector. It's important to address this issue promptly to ensure safe and reliable operation of your vehicle. To resolve the problem, it is recommended to consult a qualified mechanic or take your car to a Kia dealership. They will have the necessary diagnostic tools and expertise to identify the specific cause of the blinking lights and perform the required repairs. They may need to inspect the shift position sensor, check for transmission-related issues, or investigate potential electrical problems. By seeking professional assistance, you can ensure that the underlying problem is accurately diagnosed and properly resolved.
Hi, Kitchenaid kbfc42fts interior controls and lights blinking no alarms
If the interior controls and lights in your KitchenAid KBFC42FTS refrigerator are blinking but there are no alarms or error codes displayed, it may indicate a problem with the refrigerator's control board or power supply.
Here are some steps you can take to troubleshoot the issue:
  1. Power cycle the refrigerator by unplugging it from the electrical outlet or turning off the circuit breaker that supplies power to it. Wait for a few minutes and then plug it back in or turn on the circuit breaker.
  2. Check the refrigerator's power supply by ensuring that the electrical outlet is working properly and that the power cord is securely plugged in.
  3. Check the control board for any signs of damage or corrosion. The control board is usually located on the back of the refrigerator, behind a panel. If you see any damage or corrosion, you may need to replace the control board.
  4. Check the wiring connections between the control board and other components such as the lights, fans, and sensors. Loose or damaged wiring can cause communication issues and blinking lights.
If none of these steps resolves the issue, it is recommended that you contact a professional appliance repair service for further assistance. They will have the necessary tools and expertise to diagnose and repair the problem.
I have the Swingline Optima 45. I staple once then the light blinks and I have to open where you put in the staples close it again and it will staple once. Then I have to repeat.
Electric staplers are notoriously unreliable, but the problem you describe sounds like buildup of the adhesive -- a sort of varnish -- used to hold the staples in stick form for loading in the tool. Remove the staples and apply a light coat of 3-in-1 or other thin oil to the first two or three staples. Reload and cycle the tool. This should help you.
1helpful
I have a merits p313 electric wheelchair stop working put in new batterys the controler lights all blinking then just middle yellow blinking
have lights so not fuse blown
not much to these ..batteries .. controller .. electric motors
hard to mix up the positive and neg terminals
that is a two battery unit
check if the joystick controller or its cable is faulty
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
O/d light blinks when driveing o/d seems to be engaged car has 198000 miles and runs very good also engine light is on
O/D light blinks, but with that the check engine light is ON.--- This will make your troubleshooting easier.When the check engine light comes on, and remains on, this indicates that there is error stored in your cars computer.---- Once the computer is scanned, you will get error codes, as per that error code it will point towards faulty part, which is causing the O/D light to blink.-------- Most probably the O/D light blinks, If a problem exists in No. 1 or No. 2 solenoids or speed sensors .
--------------- For car after 1995 it requires OBD2 tool and for car before 1995 it requires OBD1 tool.------- --------- You car will require OBD1 tool.There are very few auto parts store and repair centers who have OBD1 tool.In your case you required OBD1 tool.------ You can just contact local auto-parts store and they will guide you to the nearest store who has OBD1 tool.There you can get your car scanned.If there is error set in your cars computer, then you will receive the error code.As per error code it will point towards the faulty part causing this problem in your car.------------- -------------- The codes which you get is scanning will be mostly any of this following codes:--- DTC P0500 - Vehicle Speed Sensor Malfunction
. DTC P0750 - Shift Solenoid "A" Malfunction
. DTC P0753 - Shift Solenoid "A" Electrical Malfunction
. DTC P0755 - Shift Solenoid "B" Malfunction
. DTC P0758 - Shift Solenoid "B" Electrical Malfunction
. DTC P0770 - Shift Solenoid "E" (SL) Malfunction
. DTC P0773 - Shift Solenoid "E" (SL) Electrical Malfunction
. DTC P1520 - Stop Light Switch Signal Malfunction
. DTC P1705 - Direct Clutch Speed Sensor Circuit Malfunction
. DTC P1765 - Shift Solenoid Valve SLN Circuit Malfunction
. DTC P1780 - Park/Neutral Position Switch Malfunction
--------------- Now it all depends on what code you get, as per that you can replace the following part.------- This will help.Thanks.Helpmech.
Ford econoline van leaking unknown fluid HELP!!!!!!
check your enging fluids could be brake fluid or power steering fluid. the wheelechair lift is most likley electric and does not require fluid of any kind
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
john h
Steve Pack
Steve Pack
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
