D
Feed Development Motor Error
•???? Motor lock caused by overload.
•???? Motor driver defective.
The PLL lock signal remains LOW for 2 s while the feed development motor is operating.
Either the feed motor in the back of the tube or inside the chuck where the opening of the tube sits, if you take the chuck appart there is plastic feed fins and they break off and don't feed the toner ( I would check the feed fins in the chuck first)
In general the SC 860-900 refer to HD acces error. SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
most of this add toner problem came from the toner hopper, this need to be checked by a technician to fix the four plastic mylars to see to it that they are attached and properly scrapped the toner. next is the B4 fist do you set or is the right paper size is set on the drawers? what is the jam code so we can see if were is the fault of the machine?
