Question about Coleman Powermate Powermate 5000W Generator
Coleman powermate model PM0525202 run switch position
Anonymous
SOURCE:
Anonymous
SOURCE: coleman powermate 6250 mod# PM0525303
I had the same problem on my Powermate 525500 (5500 watt) and finally manage to get in contact w/Powermate (PRAMAC) tech support. He told me that if the gen is setup for a while, the exciter loses it's magnatism. To reenergize ( jumpstart) as he called it, follow the prcedure below. Probably not for amatures.
1. start up the generator.
2. Pull off the brush cover on the end of the gen.
3. Get a 6-12 volt battery and setup w/color coated cables.
4. place the negative lead on the left side brush terminal and tap the right side brush terminal w/ the positive lead.
5. Wala....you sould have power.
One would think that this important info would be on the manual or a blog somewhere.
Good luck and have a wonderful day.
The Texajun
Posted on Sep 20, 2008
saumyar
Saumya Ranjan Sahu
  • 174 Answers
SOURCE: How can I get a owners/instruction Manual for my
follow this link to get the user manual guide as per your model no:
http://arkansas-ope.com/COLEMAN_GENERATORS.html
Posted on Jun 08, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 01, 2009
sal_kh_sab
sal sabea
  • 98 Answers
SOURCE: Coleman Powermate on/off switch broke off. Is a DIY out of the ?
there is a wire in the back of the control pad...right behind the on\off switch...once it touches the naked body of the gen. it will shut off..
Posted on Oct 11, 2009
stunt driver
Dmitry Kukushkin
  • 5 Answers
SOURCE: Coleman powermate 2500 generator :
To what I know about this model - it IS NOT inverter type. Electrical motor works pretty much like car alternator with out reftifier. The ONLY magnet on rotor is a small, 1x2 initiation magnet, that helps to start the induction current. After that, induction current thru rotor is controlled by AVR (automatic voltage regulator) in a way, that output voltage stays at needed level.
The fact that you read 2.0 volts on output - tells you that your initiation magnet is OK. One of few things went wrong, in probability order: winding on rotor, AVR module, winding on stator, brushes woar out.
Take back cover off from electric generator part, use voltmeter to measure continuity on stator (2 or 3 poles, must be within 50 ohnm), continuity of rotor thru brushes ( normally within 100ohm). If broken - have to restore windings. It is DIYable for rotor, but hardly possible for stator. If those are ok - most probably your AVR is dead, you can not test it yourself, so get a new module to try (but try to make arrangements for return, if there it was not the reason).
Just fixed Champion 3500 generator myself, purchased for $50 as broken.
Posted on Jan 13, 2010
Im replacing engine on a model pm0525202 generator. i cant get armurature off shaft
Assuming that you have removed the stator and the center bolt, (1) apply penetrating oil to space between engine shaft and armature and wait for a few minutes. (2) Then apply carb cleaner to same area and wait for a few minutes. Find a very hard piece of wood like ash or oak and place on metal part of armature and strike firmly with hammer first on one side then the other. If it does not come loose on first attempt start over from step one. The engine has tapered shaft that really holds on to armature. Huge heavy hammer will not help. What works is the vibration of the hammer blow. That is why you need hard wood. Good luck and be patient, let oil do its magic.
Nov 14, 2010 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
Sep 29, 2009 | Coleman Powermate Powermate 5000W...
Starting the Coleman Powermate 5000 generator .....
Thanks for the offer of the Premium Assistance Plan, but no thanks -- I was able to get the answer from a local department store from their "lawn & garden" center....
J
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Hello I have a coleman powermate 5000 that i need a wiring diagram for the brigg and stratton moter some of the wiring has be destroyed and i need a diagram to get it back running can you help me PLEASE....
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
125 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Tim Garcia
Tim Garcia
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
