Electrolux 504199 Dishwasher Logo
A
Anonymous Posted on Oct 03, 2013
How to reset warning A1 - Elektrolux wt 30 e - Electrolux 504199 Dishwasher
Elektrolux 1435 waar zit de temperatuursensor
We are a North American website and that isn't English and has terrible spelling of the maker!
https://www.google.com/search?q=Elektrolux+1435
What type of oil does a Nissan turbo diesel Engine 2.5L 2oo6 model take.
Any brand of 30 wt engine oil will do. Rotella 30 wt is a good brand.
Type oil for 6.75 hp 149c toro lawn mower?
30 wt. automotive engine oil. The same as you put in your car only use straight 30 wt. not a multigrade 10 w 20 .
Mar 16, 2016 • Toro Garden
1helpful
Can I use power steering fluid instead of non detergent in my pressure washer pump?
no, you might dissolve your seals and not have the proper lubricating properties. Power steering fluid is flowing against pressure and the 30 wt is simply lubricating at no pressure.
walmart and autozone carry 30 wt non detergent oil
Jan 21, 2013 • Garden
2answers
What is the Username and Password for a Cavalier provded Zhone 1518-A1 Modem Router?
Only you know your SSID( username)and Security Key(password). You can RESET the device to default settings by pushing and holding the reset button for 30 seconds or so and release. That will reset to default setting. Then you can reconfigure the SSID and Security Key, You may want to write down the info for future use. This may help: http://www.zhone.com/products/1518-A1/
What oil goes in this unit?
Hi and welcome to FixYa, I am Kelly.
This response applies only to the engine:
Use 30 WT SAE engine oil.
You can use either detergent or non-detergent oil. I recommned 3 oil changes normal oil change intervals using 30 WT SAE non-detergent oil and on the 4th oil change use a detergent 30 WT Oil.
Thanks for choosing FixYa,
Kelly
3helpful
Where do you add the oil on a DeWalt 3100psi pressure washer?
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Kelly
1helpful
I have a Mitsubishi wt 46809 with a error code of flash flash pause flash flash
That is error code 22 which means the unit had a momentary recovery from a reset. You should unplug it for 30 minutes, then plug in and try it again. This will reset the fault and if there are no other problems the unit will work ok. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
