Not true, my door is open, seals wiped and clean cycle run every month I am now on my second pump as both were costed with black mildew.Not true, my door is open, seals wiped and clean cycle run every month I am now on my second pump as both were costed with black mildew.
You can't post conmments that contain an email address.
Your model doesn't allow for door reversal on the washer due to the electrical with the door lock, but you can the dryer there is a kit you can purchase with the dryer model number
you have to inspect that switch carefully,, its actually got 2 , a secondary switch latches just before the spin cycle, I'll try and locate the part for you
Try using vinegar and distilled water. If this does not work try using a little bleach and water. Repeat till mildew is gone. Rinse thoroughly Again & Again. Everyday humidifiers should be cleaned. After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew. Mold & mildew will cause you to get very sick. If the mildew does not go away replace your unit.
there have been several situations wht rheems as far as control boards cracked heat exchangers cracked inducer assemblys and touchy pressure switches i would call to get a furnace inspection from a rheem dealer
sounds like you really need to buy a portable dehumidifier
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Hello,Not sure I can solve this but according to repair services ,HC or HE washers especially front loaders need to have the tub cleaned once a month ( at least) with bleach or a product that can be purchased at Lowes or any other appliance store. Your problem according to those I have spoken with is Mold in the system. We have bleached ours and used two of these pellets and still are having a problem. I was told that since it is the first time in a year of having this machine that it will take some more cleanings. Hope this helps. By the way we have a Frigidaire front loader.
Al
