Question about Kenmore HE2 Plus Front Load Washer
My Kenmore HE2t washer locked it will not open after unplugging and pressing button to cancel after error message how do I get door opened
    Sergeant:
  • 372 Answers
Try turning the machine on and manual advancing through a complete cycle. Then wait five minutes. Do this several times. If the problem persists, it would be best to get a qualified Technician to check the machine out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Posted on Oct 04, 2013
6ya staff
SOURCE:
Anonymous
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
Mukesh Kumar
  • 3230 Answers
SOURCE: Received an error code dl f on my Kenmore Elite
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
Posted on Jun 27, 2009
TomZS
  • 220 Answers
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Posted on Sep 03, 2009
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2 Plus Washer won't unlock
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I hVe a whirlpool duet washer 3 years old error code F3 E2 door won’t open as of now.
The E2-F3 error usually doesn't cause a door lock problem. This error relates to the water temperature sensor. Frequently, the problem is that one wire in the wiring harness has broken. Then the message doesn't get to the control board. You'll have to unplug the wiring and test each individual strand. The insulation around the wiring will make it hard to visually find the broken wire. If the wires are intact, then the temperature sensor or the control board have a fault.
With the door lock problem, I'd suspect a problem with more of the wiring or the control board. First though try pressing Cancel, Drain and Spin (to drain any remaining water) or the power button. Some Duet washers have a Fan Dry option that keeps the door locked until the washer cycle is stopped with the Power button. Alternatively, try unplugging the washer or turning it off at the circuit breaker. Wait 30 minutes and then reconnect the power. If the control board sends the message to the lock then the door should open shortly.
I hope this helps. Please add a comment with the washer model number if you would like information on the price of the control board or a parts diagram. There should be a wiring diagram and trouble-shooting sheet inside the washer near the control panel. Open the back of this section of the washer to find it.
Apr 02, 2018 | Whirlpool Washing Machines
I have a kenmore he2t washer that will not start. Door locks, buzzes for a minute then shuts off. No error codes. What could the problem be?
the door interlock is basicaly a heated switch
it locks then hold it locked
but there is a sensor to check its closed in the first place
i think the interlock sensor isnt right
replace the door interlock is the first step
http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2
here is one i found on ebay
its not cheep so shop around a bit now you know a few equivelant types .,.. and models
Dec 07, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Kenmore HE2 Plus Front Load Washer Logo
85 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
