Question about Haier 3.5 cu. ft. Chest Freezer HNCM035E
We purchased a small haier chest-type freezer in 2006. It has worked fine until the past week. It seemed to be running normally, but suddenly did not keep the food frozen solid. There was a little ffrost on the walls but not a lot. We unplugged, defrosted; and turned back on. Still does not get cold enough.
    Sergeant:
  • 295 Answers
You may have a refrigerant leak. First make sure the lid has not warped and leaving an air gap for heat to enter. That's really about all you can do without getting a tech. involved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Jan 01, 2018
6ya staff
SOURCE:
22yooper
James Helmer
  • 828 Answers
SOURCE: Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
Posted on May 16, 2008
Anonymous
  • 124 Answers
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Posted on Nov 21, 2008
christian nielsen
  • 358 Answers
SOURCE: my Haier 7cu. ft. deep freezer gets hot on the
It 's builded that way so there's not condensation around the door frame and on the walls.
Posted on Nov 04, 2009
Raz Mataz
  • 389 Answers
SOURCE: I have Haier 5 cubic foot chest freezer, model #
Yes it does. It will have to be blowing inside so look in there. You will have to take the cover off.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Posted on Jul 30, 2010
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
We experienced a Sevrer Thunder Storm in our City on 07-23-2010 and as a result had a power outage for several hours. Once the power was restored, the Haier 3.5 cu ft chest freezer is no longer working and...
Hello
Due to the heavy storm you experienced,and since the freezer was plugged during that period there might have been a negative effect from the storm on your freezer due to earth.All you need to do is to get a technician to check it out.
THANK YOU
Jul 28, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
I have Haier 5 cubic foot chest freezer, model # HCM050LA, that cools well with the green light on. When it is running it makes a very faint high pitched sound that seems to be coming from the top right...
Apr 17, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Freezer light flashes
If its a neon lamp then the flashing might be normal
Dec 24, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier 3.5 cu. ft. Chest Freezer HNCM035E Logo
215 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
