You may visit the PartFect store to repair your Samsung Galaxy Devices including Samsung Galaxy S5 Repair.
SOURCE: my samsung galaxyS keeps freezing-
No,You can just Unfreeze the Mobile Phone,.You can get the Unfreeze Code at here http://www.superunlockcodes.com/samsung-i9000-galaxy-s/rs12wp9/
and Unfreeze it.
SOURCE: i have a samsung galaxy phone and it keeps
Try clearing the RAM. Go to 'Applications' then find an app called 'Task Manager' (it is preinstalled). Click the 'RAM manager' menu on top then select 'Level 1' then press 'Clear memory'. if it still lagging, select 'Level 2', then 'Clear memory'. That should do the trick. Cheers.
SOURCE: my samsung galaxy y duos switches itself off
Cell Phone Keeps Shutting Off
Vibrations on dirty battery contacts could be the cause of this problem. Remove the battery and clean the battery contacts with methylated spirits and the battery contacts in the cell phone.
SOURCE: samsung galaxy stellar keeps freezing
I fixed mine!!! Okay. This is what you do. Make sure your phone is off and to turn it back on press Volume up and the Power on button at the same time until it says something like rebooting system at the very left top in blue. A menu will come up. Using the volume up and down, select the reboot option. It will wipe everything out, but as long as you are set up with google, you wont lose your contacts. There will be a confirmation question with a bunch of no's and a yes. Select yes using the power button. In yellow writing at the very bottom it should say that your phone has been rebooted. It will then turn on by it's self and you will have to re- set up your phone just like you had to the day you first got it. Sorry I don't remember everything word for word, but I just got off the phone with a representative and that's what he told me to do. It worked!! If it happens again though, contact your provider and tell them. They will replace your phone if it's still under warranty :)
