Initially I got the error "Out of Ink". I replaced the ink and then got the error message "Contact Service, Report Fault 15.004.45.43458. Now this message is all I get. I have searched for this error but can't find anything. Anyone have any info?
It should fall under error 15.004.45
check below link, night be helpful
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
